ABS noise?
02Type-S
ABS noise?
Post by 02Type-S »
My TL-S does that noise every time. As others stated, perfectly normal.
I DETAIL CARS - PM ME
2002 Acura TL-S
Team Arsenic - Vice Pres.
tommygun89hb
ABS noise?
Post by tommygun89hb »
the pump turns on for about 30 seconds then the abs light turns on then the pump stops and the light stays on
ABS noise?
Post by bildo16 »
tommygun89hb;99690 wrote:the pump turns on for about 30 seconds then the abs light turns on then the pump stops and the light stays on
well it sounds like you have an issue there. its expensive to fix abs problems and dont think youll get a code from autozone. i wouldnt mess with it since it isnt a major safety issue, just be aware your abs probably wont function properly.
g3integragsr
ABS noise?
Post by g3integragsr »
bildo16;99765 wrote:well it sounds like you have an issue there. its expensive to fix abs problems and dont think youll get a code from autozone. i wouldnt mess with it since it isnt a major safety issue, just be aware your abs probably wont function properly.
lol
