ABS noise?
02Type-S
ABS noise?
My TL-S does that noise every time. As others stated, perfectly normal.
I DETAIL CARS - PM ME
2002 Acura TL-S
Team Arsenic - Vice Pres.
2002 Acura TL-S
tommygun89hb
ABS noise?
the pump turns on for about 30 seconds then the abs light turns on then the pump stops and the light stays on
ABS noise?
well it sounds like you have an issue there. its expensive to fix abs problems and dont think youll get a code from autozone. i wouldnt mess with it since it isnt a major safety issue, just be aware your abs probably wont function properly.tommygun89hb;99690 wrote:the pump turns on for about 30 seconds then the abs light turns on then the pump stops and the light stays on
g3integragsr
ABS noise?
lolbildo16;99765 wrote:well it sounds like you have an issue there. its expensive to fix abs problems and dont think youll get a code from autozone. i wouldnt mess with it since it isnt a major safety issue, just be aware your abs probably wont function properly.
