I expect to get at least 161whp out of it.90CivicEx;54570 wrote:Looks good man, can't wait to see the write up on the z6 build your doing and what #'s your wanting out of it.
My Milano Red Coupe (56k, go do a B swap)
99PreludeSh
Ain't that the truth. I'll be going with Koni Yellows eventually.99preludesh;55572 wrote:Needs to be lower, its not low enough.
g3integragsr
I worked on the car a little bit today. I put the A/C belt on since this heat sucks. I also resprayed a few things that had overspray on them when the car was repainted a while ago. I changed out the plugs wires and finally got rid yof the sputtering. MSD plugs wires suck, they were what was causing my problem. I also took a few new pictures too.
99PreludeSh
SilverStreak;55647 wrote: I changed out the plugs wires and finally got rid yof the sputtering. MSD plugs wires suck, they were what was causing my problem.
And who told you to check these but you INSISTED it wasnt the problem? YES ME lol way to go
Nice wheels......:yernuts:
Ngk's ftw! Also, your sig is funny, I actually lost the gas cap for the crx yesturday. Oreillys ftw, 4 bucks.SilverStreak;55647 wrote:MSD plugs wires suck, they were what was causing my problem.
Yes you did. But to be honest, the whole ignition system was F'd. You saw the dizzy.99preludesh;55712 wrote:And who told you to check these but you INSISTED it wasnt the problem? YES ME lol way to go
So, its time for another update.
I picked up a complete D16Y8 motor, D16Z6 automatic transmission, D16Z6 dizzy, and automatic P28 ECU from rickles8099. I plan on swapping the motor out this Saturday so I'll have a few new pictures then.
For right now, I've just been cleaning up the car for Midnight Madness this Friday. I picked up a D16Z6 4-2-1 Exhaust Manifold since the Airmass header had a hole in it. I also got ahold of a '93 EX muffler, so I have the right sized muffler on my car now. It also has the OEM optional polished tip too. I've also pulled the bronze valve cover off and will be redoing it for MM. It should definitly get some attention with the new design :biggrin:
