ls/vtec, and your opinions of it.
Q10
Post by Q10 »
Who's got it? Who's had it? Tell me everything you love/hate about it, how you went about it, and the results. Im trying to decide if I want to keep it just a ls, or go the vtec route. It will be turbo'd a little later down the road, and Im not worried about cost.
:partydance:
Landon353
Post by Landon353 »
If your wanting to go boost and you already have the LS deff go LS/v. You get the torqy LS bottom end and the high flowing GSR head. When i go with a built bottom end there is no doubt in my mind im also going with the GSR head. I know Golden Eagle sells some kits for around 500 bucks I believe?
1999 Integra--Boosted at 8psi.....Garrett t3/t4, Precision 525cc, Greddy Trust front mount, Tuned on Hondata s300 by Revline Motorsports.
1965 Stang--Restoration project
03 Honda CBR 600RR
Q10
Post by Q10 »
Landon353;264182 wrote:If your wanting to go boost and you already have the LS deff go LS/v. You get the torqy LS bottom end and the high flowing GSR head. When i go with a built bottom end there is no doubt in my mind im also going with the GSR head. I know Golden Eagle sells some kits for around 500 bucks I believe?
lsv kits? I thought they were ~300?
does the gsr head flow better than the b16 heads?
:partydance:
Post by Phate »
If youre not worried about cost, dont use a B series at all.
I had a 81.50mm LSV back in the day. I used a gsr head and P30 (b16a) pistons. I used GE's lsv kit. The head was far from stock. The car ripped ass. I loved it.
The only pain in the ass with it, is buying 93 octane all the time, imo.
horn12007
Post by horn12007 »
if you do that just watch out because I'm pretty sure using a vtec head ups the compression ratio.
Post by Phate »
horn12007;264188 wrote:if you do that just watch out because I'm pretty sure using a vtec head ups the compression ratio.
OH NOSE! Not moar compression!
Also, a GSR head will give you a few more points over a B16 head. Mine was in the low-mid 12's.
horn12007
Post by horn12007 »
Phate;264189 wrote:OH NOSE! Not moar compression!
I know....horrible.
Redline
Post by Redline »
i had a ls/vtec, b18b block, type r head and trans, all stock interanls, never had it dyno but it was quick, pulled away from stock gsr all the time.
i help my buddy built his ls/vtec, full type are internals, gsr head with ported and polishe w/ match intake, crane stage 2 cams, skunk 2 valves and springs, made 263 whp tuned on crome
i didnt buy any ls/vtec kit i just blocked the head off and ran a oil line
More power coming soon
Post by Phate »
Redline;264196 wrote:i help my buddy built his ls/vtec, full type are internals, gsr head with ported and polishe w/ match intake, crane stage 2 cams, skunk 2 valves and springs, made 263 whp tuned on crome
Going to go ahead and call BULLSHIT! Well, not on stock bore. I dont know what "type are internals" are either though...
Redline
Post by Redline »
Phate;264199 wrote:Going to go ahead and call BULLSHIT! Well, not on stock bore. I dont know what "type are internals" are either though...
sorry type r, i did not see the car on the dyno but i seen the dyno slip, the car belongs to terryb18crx he is on here, he still has the car and slips, i know the car is sitting in his drive way with a bad bearing thou,
