b18b1 engine
pvtclayton
b18b1 engine
Is the b18b1 worth the time and money to build up
sharpie
pvtclayton
b18b1 engine
are turbo applications fairly simple on this engine?
sharpie
b18b1 engine
Depends on your goals. It's about as simple as any other engine. You get out of it what you put into it I've seen them anywhere from 240- about 1100whp
pvtclayton
b18b1 engine
wow thats nuts wish mine was pushin those numbers but im currently in the prosses of putting the motor in just wondering where this car is gonna go afterwards any suggestions what works best with these engines
sharpie
b18b1 engine
Honestly I suggest you read up on it and do a lot of research and decide what you want out of the motor/setup
pvtclayton
b18b1 engine
that i will do thanks for the info ill let yall know how this turns out
Landon353
b18b1 engine
If your just going to do a simple turbo bolt on (and when I say simple, its not haha) then its a great motor. The b18b motor handles boost a little better than the other b series motors. But once you get into actually building the block, i was told by my tuner that it is almost useless to build the head just because they dont flow as well as the vtec's. So you could always do (if your planning on building the block and boost) a turbo Ls/Vtec conversion (basically just put a vtec head on there..they have conversion kits on goldeneagle's website)...I believe an Ls/vtec conversion kit is like $500-$800 but im not for sure. I have a b18b that is boosted but on a stock motor, and im eventually going to build the bottom end to handle more boost, so it all depends on your goals, and boost or no boost. :PDT_Armataz_01_11:
1999 Integra--Boosted at 8psi.....Garrett t3/t4, Precision 525cc, Greddy Trust front mount, Tuned on Hondata s300 by Revline Motorsports.
1965 Stang--Restoration project
03 Honda CBR 600RR
03 Honda CBR 600RR
luvmyhondas
b18b1 engine
yes, set yourself a HP goal and intended use of the car and there are several folks that can steer you in the proper direction. IIRC @300whp is the limit on a stock LS motor, anything past that and you will need internal (and cylinder head) upgrades. ALOT of the durability of any modified (especially boosted) engine is in the tune and how it's maintained.
AKA audioguru76
79 Hondas and counting!
Landon353
b18b1 engine
luvmyhondas;250462 wrote:yes, set yourself a HP goal and intended use of the car and there are several folks that can steer you in the proper direction. IIRC @300whp is the limit on a stock LS motor, anything past that and you will need internal (and cylinder head) upgrades. ALOT of the durability of any modified (especially boosted) engine is in the tune and how it's maintained.
^Couldnt have said it better myself!
03 Honda CBR 600RR
03 Honda CBR 600RR
