Alright so I have a 97 integra with a UKDM cluster in it and im pretty sure its for a 98+. Only think that does not work is the Gas.
If I would cut the pigtails and put 98+ on would all the same color wires match up and work correctly or should i just take the dash out and swap the whole dash harness?
Gage Cluster
wanaboostDC2
Gage Cluster
97 Integra GSR - K20 Swapped Daily.
94 Integra RS - Built turbo soon to be a beast.
Your Shits Weak!
Your Shits Weak!
v-tecivic
Gage Cluster
I know its not much help. Try searching on honda-tech for guage cluster swaps. There's a couple threads that have the pinouts for different
year civic and integra clusters. It might be as simple as depinning a plug on your cars harness to the right spot.
97 civic ex turbo
13.1@112
Gage Cluster
If I remember correctly you need to swap the green circuitry board onto the new cluster.
wanaboostDC2
Gage Cluster
well i was going to do that but if i remember correctly with this UKDM one it was completly different and i would have to cut some pieces out. I'd have to check it again if so i can show a pic.andyjt;248478 wrote:If I remember correctly you need to swap the green circuitry board onto the new cluster.
Your Shits Weak!
Your Shits Weak!
wanaboostDC2
Gage Cluster
Yes I know its a **GAUGE* was an accident. GOOD JOB FOR NOTICING THAT YOU GENIUS!
You going to make fun of V-tecivic for not spelling it correctly too?
So how about you don't post if you don't have any info to help.
Your Shits Weak!
Your Shits Weak!
Gage Cluster
It's a joke. Don't be a fag.wanaboostDC2;248519 wrote:Yes I know its a **GAUGE* was an accident. GOOD JOB FOR NOTICING THAT YOU GENIUS!
Andrew
Gage Cluster
Dangercartjason
Gage Cluster
Chill. This isnt kcsr. The grammer police are not going to ban you.wanaboostDC2;248519 wrote:Yes I know its a **GAUGE* was an accident. GOOD JOB FOR NOTICING THAT YOU GENIUS!
spoon_fed_civic
Gage Cluster
yeah kcsr makes you triple check everything and have a english teacher check it over before you post.other wise someone will give you neg for something so gay as spelling errorsDangercartjason;248760 wrote:Chill. This isnt kcsr. The grammer police are not going to ban you.
