pics of damage:
All in all, from what i can see i need the following parts:
*Fender
*Hood
*Bumper
*Radiator Support
*Headlight x2 (the other has a moisture leak and is fogged)
*Turn Signal Housing
*And whatever reservoir is up in the fender that got simply destroyed.
*And then paint
First ill say, the car itself....i dont really want because of a motor mount that was cut and rewelded(not a fan of the job) that is also on the wrecked side...so im not 100% on the integrity of the weld anymore. Not to mention the interior work and whateve else this thing is going to require.
Im expecting all that to be atleast $500 bucks before paint...not including the rear bench, and the drivers seat that it also needs...so im, goin back inforth with buying the parts and hoping for the best or looking for an eg coupe or a dc2 shell....i figure if im gonna spend 1200 bucks on the car to get it to a decent stock standpoint....i should consider other options as well
...i also wanna keep my engine/trans swap..i like that part of the car
So...buy parts.....or.....buy shell..?
