no fixing this trans
Boosted_da
Post by Boosted_da »
http://www.facebook.com/photo.php?fbid= ... =3&theater
what i think happened is......... i blew up the diff and the pin came blasting through the caseing
Post by RyanA »
So you need a differential and a case half. Not a big deal. Seen MUCH worse go back together. Looks bad at first but it's typically not a big deal once you actually open the case up.
Post by Capt'n Obvious »
would be easier and cheaper to replace
Boosted_da
RyanA;281124 wrote:So you need a differential and a case half. Not a big deal. Seen MUCH worse go back together. Looks bad at first but it's typically not a big deal once you actually open the case up.
i need both halves there both cracked. but thats encouraging knowing that it typically can be fixed since i have another diff and case at a friends house
