Clutch went out at work!
Le Mans 24hrs
Clutch on my 93 accord went outat work, now I'm stuck. Anybody know how to replace? Mechanic said he can do it Tuesday.
crxlilmikey
ask redline he can replace on in like 2hrs or less
dianichi motorsorts rip visual illusions
Le Mans 24hrs
Only problem is, I can't get it into 1st gear and it's sitting at my work in the valley (chesrterfield)
drive it with no pedal, i used to do it all the time when i delivered pizzas. now i carry an extra cable in my car. you have a hydraulic clutch so you may just have a bad slave cylinder or something in which case you fix it right there in the parking lot.Le Mans 24hrs;266742 wrote:Only problem is, I can't get it into 1st gear and it's sitting at my work in the valley (chesrterfield)
Le Mans 24hrs
Slave cylinder was replaced not long ago by the guy who I bought it from. Mechanic says it's the clutch for sure.
so it was fine on your way to work, then you parked, came out to your car started car then it wouldnt go in to gear?Le Mans 24hrs;266744 wrote:Slave cylinder was replaced not long ago by the guy who I bought it from. Mechanic says it's the clutch for sure.
crxlilmikey
Le Mans 24hrs
On the driver's side of the engine there's 2 things where fluid goes in. One says brake fluid and the other one is a little that also says brake fluid and it's empty. Is the tiny one for the clutch pedal?
yes.Le Mans 24hrs;266751 wrote:On the driver's side of the engine there's 2 things where fluid goes in. One says brake fluid and the other one is a little that also says brake fluid and it's empty. Is the tiny one for the clutch pedal?
yup, you have a leak. You will need to add fluid to the small one, bleed the clutch system, then drive home.
