Guage Cluster Lights
Martin
Hi I am new to the board and to Integras as well. I have a 97 Integra LS and I noticed the guage cluster is quite dim does anyone have a link, or thread on how to replace the guage cluster lights? Thanks in advance for your help.
______________
Eric
97 Cypress Green Integra Ls.
Eric
Dabeastwthn
Once you take the cluster out (which takes 5 minutes) It's easy...turn and unlock bulbs....replace. There ya go. You might want to take some amber model paint and paint the bulbs while you're in there. Looks nicer. :biggrin: They might sell amber bulbs too but I'm cheap.Martin;191056 wrote:Hi I am new to the board and to Integras as well. I have a 97 Integra LS and I noticed the guage cluster is quite dim does anyone have a link, or thread on how to replace the guage cluster lights? Thanks in advance for your help.
2000 Accord 5spd Coupe
Do a quick search for the integra LED swap write up. It will brighten it up alot, and you can also change colors while your at it.
Dabeastwthn
Or :whs:btlfed7;191058 wrote:Do a quick search for the integra LED swap write up. It will brighten it up alot, and you can also change colors while your at it.
Martin
Thanks sounds easy enough and I will keep the paint the bulbs thing in mind.Dabeastwthn;191057 wrote:Once you take the cluster out (which takes 5 minutes) It's easy...turn and unlock bulbs....replace. There ya go. You might want to take some amber model paint and paint the bulbs while you're in there. Looks nicer. :biggrin: They might sell amber bulbs too but I'm cheap.
______________
Eric
Eric
Martin
Thanks guys I did not think about the LED option, my guess is that it would make it quite a bit brighter.btlfed7;191058 wrote:Do a quick search for the integra LED swap write up. It will brighten it up alot, and you can also change colors while your at it.
______________
Eric
Eric
