honda sleeving video
[ame="http://www.youtube.com/watch?v=YUuw2y4z ... re=related"]YouTube - Honda B-Series Sleeving[/ame]
SweetEBPSi
Post by SweetEBPSi »
The way they were putting in the sleeves, isn't that the wrong way? I thought that your supposed to use a press with a large flat piece so that each sleeve is pressed in at the exact same time which doesn't allow one sleeve to sit higher/lower than the other.
SweetEBPSi;129862 wrote:The way they were putting in the sleeves, isn't that the wrong way? I thought that your supposed to use a press with a large flat piece so that each sleeve is pressed in at the exact same time which doesn't allow one sleeve to sit higher/lower than the other.
whaaaaaat ??
every block that gets sleeved gets decked afterwards. most of the time they do a step deck where the sleeves sit a few thousandths higher than the block. that aids in the sealing... pretty much the same as o-rining the block.
SweetEBPSi
I know the sleeves sit slightly higher than the block. I just read an article in Honda Tuning how Golden Eagle sleeves blocks and was just asking the question. And thats how they did it. They took a press with a plate and pushed all the sleeves in at once. I was more or less saying/asking from a curious standpoint.
luvmyhondas
Post by luvmyhondas »
neato!
