Any-1 Do Exhaust Work/Welding?
Digital Sol
Post by Digital Sol »
Im wanting to re-do my exhaust system, mainly because my current set-up has changed so many times there are welds everywhere and there are several pin-hole leaks throughout the system. Starting fresh id also be able to fix some "low clearance" issues and the angle of the muffler. Ill also need an 02 bung welded into the system as well. Shouldnt be too bad considering the current system on there is on and working fine, just wanna start fresh with new piping and eliminate some issues from the start. Im ordering SS piping but will need to have it all welded and such'. Just curious if any-1 here does any sidework like this or know someone that would be interested.
Post by Gunmetal Si »
tom
JVolsch
Post by JVolsch »
There should be a couple of O2 bungs, in that test pipe. (If you still have the Kteller one)
Digital Sol
JVolsch;88054 wrote:There should be a couple of O2 bungs, in that test pipe. (If you still have the Kteller one)
whats "toms" user name?
test pipe? only kteller pieces i have is a resonator, current high flow cat is actually just hollowed out but when i have the exhaust redone there will be no cat/test pipe, just straight piping all the way through besides my kteller resonator etc'.
Post by andyjt »
Digital Sol;88159 wrote:whats "toms" user name?
t-rock
Digital Sol
thanks
