4x114
4x114.3
I am looking for a good set of 4X114.3 wheels that would look good on a first gen RX7. I really like the ones that are on there, but I need a second set for track tires.
big pipe
4x114
Post by big pipe »
4x114 is the same as 4x114.3, people are just too lazy to add the .3
a third of a millimeter isnt very much
4 lug S13's wear the same size shoes, you might have better luck searching under that
on ebay if you search 4x114 you will find some decent deals
just make sure you go with a rwd offset
this space for rent
4x114
Post by bildo16 »
check out takumi project,scoop up some watanabe rs's!
Dabeastwthn
4x114
Post by Dabeastwthn »
btlfedgolf;86367 wrote:I am looking for a good set of 4X114.3 wheels that would look good on a first gen RX7. I really like the ones that are on there, but I need a second set for track tires.
Quite a few cars use that pattern. For example:
90-96 Accords
92-96 Preludes
Just put in the 4x114.3 or 4x4.5 (same thing) on any search and you'll find a lot of them. Too bad it's for track use or you could do what I did and use 3/4" thick 4x114.3 to 4x100 wheel adapters so you could have even more choices. :dunno:
2000 Accord 5spd Coupe
JVolsch
4x114
Post by JVolsch »
infiniti g20's and 00+ nissan sentras also use that bolt pattern.
Its Pat!
4x114
Post by Its Pat! »
stock sentra wheels would go on that car nicely. or maybe some rotas with drag radials already mounted would suit your fancy.
spray the way
TEAM AGR: Actual Garage Racing. GMR has nothing.:PDT_002:
