Question about 16x7.5" wheels
J.M.P
Post by J.M.P »
I know a lot of you are very full of info on any Honda, and I have searched and really kinda came up with nothing, or I missed it. Tried on the Fitfreak forum and no help there. Here is what I am asking.
I am wanting to buy a set of Kosei K1's that are for sale locally. I want to know if they will rub or not. The size on them is 16"x7.5". Offset is +32. I know this size rubbed with tires on my Integra, but not sure on the Fit. Its a 2010 Sport.
Also, if these won't rub, what size tire would you recommend?
Also I guess I will ask, what size wheels with offset would be the best bet. I would like to stick with 16's, maybe 17's.
Thanks so much guys.
-2010 Honda Fit
-2000 EBP Civic SI
eh2_Erik
Post by eh2_Erik »
I also had a set of those on my old integra, they rubbed on the rear upper control arm. is that what you're refering to? if so a simple spacer will do, 5mm would be fine.
as far as tires go, i'd do a 205/45 or even a 205/50 depending on how low you wanna go.
Now s13_Erik
Uncle_Willie
Post by Uncle_Willie »
What are these wheels coming off of? And when you say rub do you mean rub suspension parts or rub your wheel wells?
1992 Civic Dx Sedan
l D15B Vtec l Tucked l lowered l Fit Sport Wheels
1998 Civic Ex Coupe l Ls-Vtec l Eibachs
1994 Honda Elite SR50 l 72cc Malossi Big Bore l Full Bolt-ons l plastics stripped
1994 Honda Elite l 6800 miles l Blown up
J.M.P
Post by J.M.P »
They rubbed the upper control are like Erik said. But that was on my Integra, totally different vehicle this time. I am wandering if the same problem will arise. I am sure the suspension is a bit different and setup different. But I am also concerned about rubbing the fenderwell as well.
-2010 Honda Fit
-2000 EBP Civic SI
Post by Phate »
Go ask the guy if you can test fit them. But like Erik said, worse case you might need a small spacer.
