Dyno day numbers 8-11-07
Ok well today was dyno day and I figured I would post up my numbers.
205 and 157 on 7 psi with a few boost leaks, fouling out the plugs, and a LS basemap/chip in a p28 ECU for my stock B16 on boost of course. Im very impressed considering it didnt blow up and it drives fine considering we changed plugs. So everyone feel free to post up your numbers.
Post by N2HIFI »
took the new car for some base line numbers and came up with
119.7 hp
105 tq
nothing serious but a good start considering this is a thrown together motor that is begging for boost.
chris
Kage87
Post by Kage87 »
1st 127.2 hp/125.1 tq
2nd 128.1 hp/123.2 tq
3rd 127.7 hp/125.3 tq
edit: P.S. I wanna see those pictures guys so post 'em up!
-Kyle
"Le Bon Temps Viendra"
'93 Civic DX Coupe
  • D16Y8 Swap
  • D16Z6 Automatic Transmission
  • P28 ECU
  • Stock '92-'95 EX I/H/E setup with an OBX Resonated Test Pipe
Well, I guess the automatics kind of freaked out the dyno. But this was my best run :biggrin:
Max Power=140.5(HP) @ 5100 RPM, Max Torque=144.7(ft. lbs.) @ 5100 RPM
Avg. HP=91.5HP, Avg. Torque=117.0 ft. lbs., Temp=84.6
Heres what the most accurate run was
Max Power=113.4(HP) @ 6000 RPM, Max Torque=101.1(ft. lbs.) @ 4550 RPM
Avg. HP=97.5HP, Avg. Torque=91.0 ft. lbs., Temp=84.7
I'm really pleased with the numbers. The stock Y8 in the '96-'00 Civics put down 128HP and 102TQ at the crank. Its time for more upgrades :icon_geek:
:pics:
Post by andyjt »
My numbers:
172.3 hp, 115.4ft.tq.
Stock B16B, Apexi 3in Exhaust and 3in Test pipe, and a crappy Short ram Intake.
vs. old dyno of 168hp 112ft/tq. (2.5in test pipe and 2.25in exhaust)
I pleased with my results, considering the hot temp, etc.
Kage87
Post by Kage87 »
SilverStreak;60411 wrote:Well, I guess the automatics kind of freaked out the dyno. But this was my best run :biggrin:
we're showing our freak runs are we, well in that case my best run was a 129.5 hp/ 176 tq :wtf2:
-Kyle
Silver Knight
Post by Silver Knight »
145.1 hp @7300 / 118.8 tq @6100
145.5 hp @7650 / 111.8 tq @6450
148.8 hp @7250 / 121.7 tq @6000
DC5
99BlackHatch
Post by 99BlackHatch »
Didn't get to run...
Maxed out my MAP sensor at 4,500 rpms and created peak boost at 11 psi... Time to change the MAP to a 3 bar so I can finish getting tuned!
SquadronOne.net
Potts1
Post by Potts1 »
wow aj, i was thinking you were gonna blow up your motor today on the dyno.
-Potts
JesSi
Post by JesSi »
Potts1;60462 wrote:wow aj, i was thinking you were gonna blow up your motor today on the dyno.
We had some scares but it held together.
