USDM ITR Production Numbers
xslickwhitetegx
Post by xslickwhitetegx »
I didn't write this and never seen this before. Just thought I'd share cause its GREAT about itr!
The background:
Between a previously posted letter and personal contacts, several of us have heard an answer to this question from folks at American Honda, that the numbers sold for model years '97, '98, '00, and '01 were 318, 1023, 1347, and 1157, respectively, for a total of 3,845 ITRs. But some folks here have been looking for documented proof of those numbers, beyond that already available. It is now possible to get such proof. Here's how.
Every ITR sold in the United States has a VIN (vehicle identification number) in the format JH4DC231cySnnnnnn where:
c is a check digit, calculated as shown on this web page, where it says "What is a Check Digit and how is it calculated?" (The examples and information shown are for NSXs, but the calculation itself applies to ITRs as well)
y designates the model year of the car (V=1997, W=1998, Y=2000, and 1=2001)
nnnnnn is a sequential numbering of the cars produced (that does not have ANY relationship to the ITR numbers on the armrests)
Therefore, it is possible to use a computer to calculate the check digit, and therefore the VIN, for all possible VINs for ITRs sold in the United States.
It is also possible to take each VIN and verify whether it was or was not ever a valid VIN for an ITR, by entering it into the "My Acura" section of Acura's website. The website will indicate whether or not it is a valid VIN, and if so, will also indicate the color of the car. If someone does this, he can compile a list of all valid VINs of every ITR sold in the United States, and identify the color of each one. This will give us a total number of ITRs and a breakdown by color.
The problem in doing so is that this process involves entering thousands of VINs into the website to verify which ones were actually ITRs. This will require a fair amount of work. In fact, it might be so much work that it's impractical; I don't know. More specifically, I don't know how high the VIN sequence number (that nnnnnn part of the VIN) goes each year. If there was one VIN sequence for all Integra versions, including two and four doors, GS-R and SE and LS and GS as well as ITRs, there may be so many possible VINs to check that it's impractical to check all of them. (Integras were selling at a rate of approximately 40,000 cars a year in the States when the ITR first came out in 1997, although that figure dropped to around 14,000 a year by 2001, as shown in the figures here; note that those figures show sales by calendar year rather than model year.) But if the ITRs were only produced in a small number of "runs" during the manufacturing process, it might be feasible to check only the ranges of VIN numbers in and around those runs, so that only a few thousand VINs for each year would need to be checked instead of tens of thousands. Unfortunately, I don't have any idea how to go about isolating which portions of the sequence number series would contain all the ITRs. EDIT - since originally writing this post, I found out that there are four sequences of USM Integra VIN numbers each year, and exactly how high they go for each year's sequence for manual hatches
If this sounds too complicated and impossible, it's not. Someone on NSXprime went through exactly this process to determine the VINs of NSXs sold in the U.S. in recent years, identifying each one by color, transmission, and body style. Granted, it was easier with NSXs because it was only a few hundred each year, all using one sequence of VINs with no non-NSXs mixed in, so there were only a few hundred to check without having thousands of GS-R or LS Integras mixed in (and again, I don't know whether or not that's the case with the VIN sequence numbers used for the ITR). But still, if it's possible for someone to do that with the NSXs, it's possible for someone to do that with the ITRs.
Maybe there is someone here (or several someones here) who might be interested in taking this on. Someone with the computer skills to program the algorithm to calculate the check digit for each possible VIN, and someone to spend the time entering the list of possible VINs into Acura's website to verify which ones were sold as ITRs (and find out the color of each).
Ok, here are the answers.
Total USDM ITR Production by Year
(numbers in parens are the previously accepted totals)
1997 320 (318) 320 CW (100%)
1998 1002 (1023) 1002 CW (100%)
2000 1355 (1347) 573 FBP (42%) 782 PY (58%)
2001 1173 (1157) 523 NBP (45%) 650 PY (55%)
Grand Totals by Color
3850 Total
1322 CW (34%)
1432 PY (37%)
1096 *BP (29%)
573 FBP (15%)
523 NBP (14%)
UKDM Whore
Post by andyjt »
Let me add more.... For the maybe 5 ITR owners on this site :D
Disclaimer: This is not mine. Got it from Rob (Bbasso) on ITRCA.com
20001 Integra Type R status vs. location
2001 #1704 alive -NY
2001 #1161 dead -WA
2001 #1150 alive -NY
2001 #1141 alive -MN
2001 #1140 alive -NJ
2001 #1139 alive -TX
2001 #1135 alive -FL
2001 #1125 alive -AZ
2001 #1122 alive- NJ
2001 #1117 alive -GA
2001 #1111 alive -FL
2001 #1026 alive -HI
2001 #1107 alive -IL
2001 #1106 alive -WI
2001 #1097 dead -CO
2001 #1094 alive -TX
2001 #1091 alive -IL
2001 #1076 alive -VA
2001 #1075 alive -FL
2001 #1071 alive -GA
2001 #1061 alive -CA
2001 #1059 alive -CA
2001 #1053 alive -CA
2001 #1047 alive -CA
2001 #1046 alive -CA
2001 #1044 alive -CA
2001 #1038 alive -TX
2001 #1037 alive -NY
2001 #1032 alive -TX
2001 #1028 alive -TX
2001 #1027 alive -CA
2001 #1026 alive -CA
2001 #1014 alive -NE
2001 #1010 alive -NJ
2001 #1008 alive -FL
2001 #1004 dead -FL
2001 #990 alive -CA
2001 #982 alive -PA
2001 #977 alive -CA
2001 #974 alive -LA
2001 #973 dead -NY
2001 #972 alive -NV
2001 #962 alive -CA
2001 #959 alive -??
2001 #957 alive CA
2001 #954 alive -CA
2001 #950 alive -VA
2001 #948 alive -NC
2001 #944 alive -TX
2001 #940 alive -MI
2001 #936 alive -CT
2001 #933 alive -IL
2001 #928 alive -MD
2001 #925 alive -CA
2001 #918 alive -GA
2001 #909 alive -NJ
2001 #907 alive -IN
2001 #899 alive -KY
2001 #895 alive -CA
2001 #886 alive -FL
2001 #884 alive -CA
2001 #878 alive -OR
2001 #877 alive -OH
2001 #873 alive -CA
2001 #864 alive -VA
2001 #863 alive -FL
2001 #862 alive -TX
2001 #851 dead -FL
2001 #848 alive -NC
2001 #843-alive -CA
2001 #839 alive -NY
2001 #834 alive -MI
2001 #833 alive -MN
2001 #828 alive -SC
2001 #821 dead -CA
2001 #817 dead -CA
2001 #815 alive -CA
2001 #802 alive -CA
2001 #801 alive -FL
2001 #799 dead -VA
2001 #798 alive -OH
2001 #793 alive -OH
2001 #786 alive -PA
2001 #772 alive -AZ
2001 #769 alive -NY
2001 #765 alive -GA
2001 #762 alive -PA
2001 #761 alive -NY
2001 #756 alive -MA
2001 #743 alive -PA
2001 #741 alive -GA
2001 #731 alive -CA
2001 #732 alive -CA
2001 #720 alive -MD
2001 #716 alive -CA
2001 #714 dead -NJ
2001 #708 alive -NY
2001 #704 alive -NY
2001 #703 dead -PA
2001 #700 alive -CO
2001 #696 alive -IA
2001 #695 dead -CA
2001 #692 alive -VA
2001 #691 dead -VA
2001 #689 alive -NC
2001 #687 alive -IL
2001 #686 alive -IL
2001 #682 alive -PA
2001 #680 alive -CA
2001 #679 Alive -FL
2001 #676 alive -CA
2001 #675 alive -CA maybe NC
2001 #673 alive -VA
2001 #666 alive -??
2001 #650 alive -TX
2001 #649 alive -NY
2001 #640 alive -MO
2001 #622 dead -NY
2001 #621 alive -CA
2001 #620 alive -VA
2001 #611 alive -NY
2001 #585 dead- FL
2001 #581 dead -NC
2001 #569 alive -MD
2001 #559 dead -FL
2001 #554 alive -IL
2001 #542 alive -CA
2001 #538 alive -WA
2001 #536 alive -CA
2001 #531 alive -CA
2001 #528 alive -CA
2001 #525 alive -CA
2001 #520 alive -CA
2001 #516 alive -VA
2001 #514 alive -CA
2001 #510 alive -HI
2001 #506 alive -SC
2001 #495 alive -CA
2001 #492 alive -NV
2001 #491 alive -CA
2001 #489 alive -CA
2001 #486 alive -CA
2001 #485 alive -CA
2001 #484 alive -CA
2001 #476 alive -TX
2001 #475 dead -GA
2001 #465 alive -CA
2001 #462 alive -CA
2001 #458 alive -DE
2001 #457 alive -CA
2001 #454 alive -CA
2001 #443 alive -DE
2001 #441 alive -CA
2001 #436 alive -CA
2001 #431 alive -CA
2001 #422 alive -CA
2001 #417 alive -NY
2001 #415 alive -OH
2001 #408 alive -CA
2001 #407 alive -MD
2001 #401 alive -NC
2001 #400 alive -CA
2001 #399 alive -HI
2001 #386 alive -PA
2001 #380 alive -VA
2001 #361 dead -PA
2001 #360 alive -OR
2001 #351 alive -WI
2001 #349 alive -AZ
2001 #348 alive -IL
2001 #347 dead -CA
2001 #342 alive -MD
2001 #341 alive -MD
2001 #339 dead -WI
2001 #338 alive -FL
2001 #336 alive -NV
2001 #332 alive -IL
2001 #326 alive -CA
2001 #330 alive -KS
2001 #320 alive -OH
2001 #318 alive -WI
2001 #317 alive -TX
2001 #313 alive -VA
2001 #310 alive -NC
2001 #299 alive -VA
2001 #293 alive -OR
2001 #288 alive -VA
2001 #287 alive -MD
2001 #286 alive -OK
2001 #280 alive -OH
2001 #275 alive -OH
2001 #265 alive -IN
2001 #264 alive -VA
2001 #258 alive -MO
2001 #257 alive -MD
2001 #252 alive -CA
2001 #251 alive -Al
2001 #248 alive -MD
2001 #244 alive -FL
2001 #234 alive -FL
2001 #233 dead -NY
2001 #226 dead -WV
2001 #223 alive -FL
2001 #222 alive -MA
2001 #220 alive -NY
2001 #213 alive -NY
2001 #206 alive -PA
2001 #205 alive -CA
2001 #202 alive -CA
2001 #199 dead -NY
2001 #198 alive -NH
2001 #195 alive -FL
2001 #193 alive -VA
2001 #186 alive -NM
2001 #184 alive -Germany
2001 #177 alive -GA
2001 #173 alive -VA
2001 #168 alive -CA
2001 #166 alive -NJ
2001 #161 alive -SC
2001 #160 alive -NC
2001 #159 dead -TN
2001 #152 alive -FL
2001 #149 alive -AZ
2001 #148 alive -AL
2001 #142 alive -IA
2001 #133 alive -NC
2001 #133 alive -NC
2001 #131 alive -NJ
2001 #128 alive -GA
2001 #120 alive -NY
2001 #112 alive -CA
2001 #110 alive -AZ
2001 #105 dead -NY
2001 #102 dead -NY
2001 #096 dead -TX
2001 #089 alive -NC
2001 #081 alive -CA
2001 #081 alive -CA
2001 #078 alive -FL
2001 #072 alive -CA
2001 #070 alive -NJ
2001 #052 alive -CA
2001 #049 alive -WA
2001 #045 alive -TX
2001 #042 alive -WA
2001 #041 alive -WA
2001 #037 alive -WA
2001 #036 alive -OK
2001 #031 alive -PA
2001 #030 dead -NY
2001 #026 alive -NY
2001 #021 alive -GA
2001 #013 alive -FL
2001 #005 alive -PA
2001 #004 alive -FL
2001 #00? PY -USA
2001 #00? B-92P -USA
2001 #00? NH-592P -USA
2001 #00? NH -0 -USA
Canada------------------------------------------------------------------------------------
2001 #1343 alive -Canada
2001 #1315 alive -Canada
2001 #1312 alive -Canada
2001 #1289 dead -Canada
2001 #1288 alive -Canada
2001 #1287 alive -Canada
2001 #1269 alive -Canada
2001 #1268 alive -Canada
2001 #1255 alive -Canada
2001 #1251 alive -Canada
2001 #1250 alive -Canada
2001 #1248 alive -Canada
2001 #1247 alive -Canada
2001 #1244 alive -Canada
2001 #1243 alive -Canada
2001 #1242 alive -Canada
2001 #1240 alive -Canada
2001 #1229 alive -Canada
2001 #1224 alive -Canada
2001 #1194 alive -Canada
2001 #1187 alive -Canada
2001 #1185 alive -Canada
2001 #1180 alive -Canada
2001 #1177 alive -Canada
2001 #0670 alive -Canada
2001 #000? alive -Canada
Puerto Rico-----------------------------------------------------------------------------------
2001 # 1299 -Puerto Rico
2001 # 904 -Puerto Rico
2001 # 754 -Puerto Rico
Thank you.
Post by andyjt »
Integra Type R Registry :
http://www.integratyper.org/
ObsesionWitSped
Post by ObsesionWitSped »
So a USDM ITR made its way over to Germany?
Talking about Andy's drop:
Post by andyjt »
ObsesionWitSped;150300 wrote:So a USDM ITR made its way over to Germany?
Yeah. If your in the Military you can take a car to the base in another country while your on active duty.
Post by Gunmetal Si »
^^^^^^^^^^^are u 640 or 258^^^^^^^^^^^
Post by andyjt »
GUNMETAL SI;150354 wrote:^^^^^^^^^^^are u 640 or 258^^^^^^^^^^^
I'm 2000-??? Based on my vin im somewhere in the high 850's until 9something.
