so i went n and got my alignment......and i was told my rear passenger toe arm would not adjust ENOUGH to get the degree mark in the green.........
...why would it not b able to now, i mean it had to b str8 once upon a time and what are my options, i seen the megan racing toe arms but if its something simple id like to avoid that
toe issues cont.
92_luder
toe issues cont.
Clayton
toe issues cont.
something is bent or the tech couldn't get it loose or was to lazy to adjust it/didn't know how.92_luder;272314 wrote:so i went n and got my alignment......and i was told my rear passenger toe arm would not adjust ENOUGH to get the degree mark in the green.........
92_luder
toe issues cont.
i doubt anything is bent.....its never been wrecked...its never been jacked up by the toe arms......im guesssin its jus him.....i dont think he adjusted my camber either.......06sik20z3;272316 wrote:something is bent or the tech couldn't get it loose or was to lazy to adjust it/didn't know how.
toe issues cont.
Worn the hell out trailing arm or control arm bushings?
Uncle_Willie
toe issues cont.
^^Probably this. Energy suspension trailing arm bushings are 30 bucks and arent too bad to put in.RyanA;272347 wrote:Worn the hell out trailing arm or control arm bushings?
1992 Civic Dx Sedan l D15B Vtec l Tucked l lowered l Fit Sport Wheels
1998 Civic Ex Coupe l Ls-Vtec l Eibachs
1994 Honda Elite SR50 l 72cc Malossi Big Bore l Full Bolt-ons l plastics stripped
1994 Honda Elite l 6800 miles l Blown up
toe issues cont.
It's very well possible that something could be bent. And there's more suspension components then just compensator arms that affect toe.92_luder;272320 wrote:i doubt anything is bent.....its never been wrecked...its never been jacked up by the toe arms......im guesssin its jus him.....i dont think he adjusted my camber either.......
92_luder
toe issues cont.
i have new energy bushings back there and yeah i guess that makes sense.....but bent from what?JustRob;272378 wrote:It's very well possible that something could be bent. And there's more suspension components then just compensator arms that affect toe.
Uncle_Willie
toe issues cont.
A previous owner could have slid it into a ditch or curb or something in the snow at some time. Ive seen that happen alot but people never consider the damage it does.92_luder;272409 wrote:i have new energy bushings back there and yeah i guess that makes sense.....but bent from what?
