diy master cylinder
diy master cylinder
Post by Capt'n Obvious »
must have flare nut wrenches
sockets and wrenches
1- loosen the brake lines with flare nut whenches if you dont use em you will strip em then youll be fucked
-notice cup under you wil loose some fluid
2- take off those nuts holding it on to the booster
3- take it off after taking off brake lines
4- empty resivour
5- loosen this bolt
6- carefully take off resivour
7- clean it
8- put resivour on new one
9- put those nut things in and tubes
10- add fluid
11- pump the deal till there is no more bubbles in the line
12- this is a tool i keep in my box it comes in handy in tight spaces
13- button everything up
this is how i got to that nut its hard to get to
14- bleed brakes always a bitch
diy master cylinder
man land
