Do powerslots rust?
zacs2k
Do powerslots rust?
Post by zacs2k »
Tomorro(sp?) i am going to install my pads and powerslot rotors because my are warped to shit. my question is do they rust? I went to buy some clear coat caliper paint to sray them with it but they were out some im just gonna leave them be.
thanks
Zac
stlgolf.net
Do powerslots rust?
All break rotors rust. to get rid of the rust simply hit your breaks, its just surface rust. I dont think its such a hot idea to paint your rotors.
99PreludeSh
Do powerslots rust?
Post by 99PreludeSh »
so you are going to paint your rotors for the paint to come off when you stop?
zacs2k
Do powerslots rust?
Post by zacs2k »
i was wanting to paint them so the parts that aren't touched by the pads dont rust, i know the rust on the part that the pads stop on will just come off when i use them
btw how do i check my blinker fluid?
stlgolf.net
risktypes
Do powerslots rust?
Post by risktypes »
94gsr;136742 wrote:i was wanting to paint them so the parts that aren't touched by the pads dont rust, i know the rust on the part that the pads stop on will just come off when i use them
LMFAO..there is no such thing as blinker fluid. but hey check out your muffler bearings.
I know what you're talking about, the parts that dont touch such as the rotor "bells" as i call them. Don't know the actual technical term for them. Rotora has them already coated but since you don't have them you could paint them whatever color but i do know rotora states they "E-coat" their shat. don't know if it's a special paint or what.
myspace.com/jinlee
Clayton
Do powerslots rust?
Post by Clayton »
oh thank god your not that much of a moron, i painted mine with caliper paint
Midori
Do powerslots rust?
Post by Midori »
rotors=Iron
Iron+water=Rust
i painted mine with caliper paint also.
powerslot "plus" rotors dont rust because theyre 2 pieces, one not made of iron and painted
-'11 Taffeta White CR-V
risktypes
Do powerslots rust?
Post by risktypes »
MidoriMiller;136898 wrote:rotors=Iron
Iron+water=Rust
Those are big brake kits. Powerslot also makes OEM spec rotors. I like my Rotora's tho especially with the E-coat. Never did like the rust look on the bell area.
myspace.com/jinlee
Midori
Do powerslots rust?
Post by Midori »
but the oem replacement rotors will rust unless he paints them.
risktypes
Do powerslots rust?
Post by risktypes »
Can't win em all.
myspace.com/jinlee
