brake light switch
civicex
brake light switch
i changed it, lights still stay on i'm at a loss.
PSN: DumbRands
Diablo 2 Lord of Destruction: USeast acc: caution-cold
Clayton
brake light switch
not adjusted right or missing your stoppercivicex;298324 wrote:i changed it, lights still stay on i'm at a loss.
my pay pal is littlebastard666@msn.com
civicex
brake light switch
what do you mean adjusted right? i still have the stopper in there.Clayton;298325 wrote:not adjusted right or missing your stopper
PSN: DumbRands
Clayton
brake light switch
read your post wrong thought you said the dont come on. ricks right the car needs to be soldcivicex;298327 wrote:what do you mean adjusted right? i still have the stopper in there.
and you probably still need to adjust it. the switch acts as an open until the pedal is pressed then it closes copleting the circuit.
brake light switch
I just came home to my civic with the brakelights staying on constant. I didn't know what happened....
checked inside and saw that the rubber stopper broke/tore apart. I am guessing it is because of the constant heat the past few weeks....otherwise I don't know.
Put another rubber switch stop in and works like it used to.
