i would like to use someones stock p28 for a few minutes. i am trying to diagnose my cel, and im thinking my car has been boosted before. its running super rich, there is an oil line tapped in the front of the pan, and there is a cut out in the front where it looks like an intercooler could have sat. also a resistor box to the right of the brake booster.
the ecu wire harness is a hack job, and im getting desparate to get my car, speedo, and vtec all working properly.
completely stock p28
IF you want to run like stock, just open the ECU and make sure the jumper by the chip is removed. You will then be running on the basemap in the ECU.
Uncle_Willie
Good luck. After seeing a couple cars that had been boosted I can say that I hope I never have to fix a wiring issue in one.
1992 Civic Dx Sedan l D15B Vtec l Tucked l lowered l Fit Sport Wheels
1998 Civic Ex Coupe l Ls-Vtec l Eibachs
1994 Honda Elite SR50 l 72cc Malossi Big Bore l Full Bolt-ons l plastics stripped
1994 Honda Elite l 6800 miles l Blown up
kennbe
do you have a link for a diy by chance?RyanA;276561 wrote:IF you want to run like stock, just open the ECU and make sure the jumper by the chip is removed. You will then be running on the basemap in the ECU.
