Okay so I repinned "connector A" on my 96 civic. I am now getting a code 17 which is VSS Vehicle speed sensor. all gauges read fine. That sensor is on "connector C" which i didn't touch. The Check engine doesn't come on right away either it normally takes about a mile or two. The thing is is that VTEC isn't engaging either and I have noticed that the check engine light will also come on if I rev past 6k. I am running on a OBD1 P30 with a zerg conversion harness which I have had for over a year now with no problems. Any ideas?
This might help some who are not familiar with OBD2a or my connector descriptions.
http://ff-squad.com/technet/wiring.obd2a.htm
CODE 17 after repin
HondaChild
CODE 17 after repin
Know your roots.
