iac code 14 help...
twistedone_85
iac code 14 help...
Post by twistedone_85 »
Heres my problem ive got a 99 ex head on top of a 94 delsol lower end. my car was converted to a 5 spd obd1 computer whats happening is that when i step on the gas it goes nowhere it wont move it sounds like its falling on its face then it will pick up and go. i also have a 3in throttle body on it. i need help please i need to get this car running so i have one for work the wife is getting pissed at me for using her car. help me out thanks. kyle
iac code 14 help...
Post by rickles8099 »
go back to a stock 56mm throttle body or at most a b series tb. second, check your cam timing and ignition timing, my bet is at least one of them is off
luvmyhondas
iac code 14 help...
Post by luvmyhondas »
make sure you didn't swap the IACV and IAT plug.
iac code 14 help...
Post by Capt'n Obvious »
luvmyhondas;211759 wrote:make sure you didn't swap the IACV and IAT plug.
thats what happened to me
tommygun89hb
iac code 14 help...
Post by tommygun89hb »
those are the same exact symtoms of matts car before I found the problem.
iac code 14 help...
then yelled at me
tommygun89hb
iac code 14 help...
your right i did yell at you buddy LOL but you learnd an important lesson that day didnt you. If i had a wooden ruller then i would have hit you with it
