tps sensor question
jdmjerry07
tps sensor question
Post by jdmjerry07 »
I have a blox 68mm on the way, when recently put the gsr tb on couple weeks ago it ran fine with the stock tps on. Will i be ok for awhile until i get a new one, or are the recommened to be put on right away.
SPORK IS COOL! HE ANSWERS QUESTIONS!
g3integragsr
tps sensor question
Post by g3integragsr »
Im confused what your asking jerry....
Are you asking if you should reuse the stock TPS on your new throttle body?
Or
Use the New Throttle body.....run it without a TPS until you buy a new sensor?
You cant swap the stock TPS to the Blox Throttle body and it will be just fine
jdmjerry07
soooo
The last part answered my question guess i dont need a new one then but, then why does alot of companies sell them as a package deals and things as if you need to have them?
Midori
tps sensor question
Post by Midori »
the blox tb doesnt come with a tps on it you have to put either the tps from your stock tb or the one from your gsr tb, either way you have to take one off
-'11 Taffeta White CR-V
tps sensor question
jdmjerry07;88807 wrote:The last part answered my question guess i dont need a new one then but, then why does alot of companies sell them as a package deals and things as if you need to have them?
Not everyone knows that, so the answer is profit.
jdmjerry07
tps sensor question
yeah thats why i asked first cause thats what it sounded like, and yes josh i no i need one on there bud just wanted to no if i needed a new one.
g3integragsr
tps sensor question
You dont need a new one.....the reason people just buy new ones is because of the bolts they use on the factory ones....you have to cut the bolts off with a dremel to get the tps off. It's not hard to do, it just scares people
jdmjerry07
tps sensor question
just unscrewed mine? didnt have to dremel anything, are alot stuck in there or something?
tps sensor question
Post by Gunmetal Si »
what are u putting a 68mm tb on???????????
v-tecivic
tps sensor question
Post by v-tecivic »
jdmjerry07;88827 wrote:just unscrewed mine? didnt have to dremel anything, are alot stuck in there or something?
if you don't have a dremel, you can use a hack saw and cut a line on the top of the bolts. then use a flathead screwdriver to get 'em out.
97 civic ex turbo
13.1@112
