speed signal wire?
Cfh99Hc
speed signal wire?
Post by Cfh99Hc »
i cant find any write-up's or diagrams for finding the speed signal wire on the ecu harness for hooking up a turbo timer...any help would be great!!
speed signal wire?
Post by stolle »
Cfh99Hc;13552 wrote:i cant find any write-up's or diagrams for finding the speed signal wire on the ecu harness for hooking up a turbo timer...any help would be great!!
what turbo timer? try searching for "vss" or vehicle speed sensor...
Team NOCO Crew Member #2
Cfh99Hc
speed signal wire?
Post by Cfh99Hc »
stolle;13560 wrote:what turbo timer? try searching for "vss" or vehicle speed sensor...
Greddy,i bought the plug n'play harness for it also.i just found a thread in H-T,but they dont mention anything about the speed signal wire....maybe it doesnt apply to hondas im guessing
speed signal wire?
Post by 5thgen »
might want to list the type of car.
99 civic I'm guessing?
http://www.apexi-usa.com/pdfWiring/2.pdf
speed signal wire?
Post by stolle »
Cfh99Hc;13565 wrote:Greddy,i bought the plug n'play harness for it also.i just found a thread in H-T,but they dont mention anything about the speed signal wire....maybe it doesnt apply to hondas im guessing
i didnt have to mess with the vss signal when i put mine in but mines apexi. did you try greddy's site for a manual?
Cfh99Hc
speed signal wire?
Post by Cfh99Hc »
5thgen;13567 wrote:might want to list the type of car.
yeah,but i just switched over to an obd-1 p28 so...
Cfh99Hc
speed signal wire?
Post by Cfh99Hc »
stolle;13569 wrote:i didnt have to mess with the vss signal when i put mine in but mines apexi. did you try greddy's site for a manual?
yeah but its setup for all applications
speed signal wire?
Post by rickles8099 »
try pin c18
Cfh99Hc
speed signal wire?
Post by Cfh99Hc »
ill be starting the install tom. afternoon,so if i run into any problems ill post em up
speed signal wire?
Post by 5thgen »
for obd 1 it should be middle plug, pin 10 (b10).
http://www.apexi-usa.com/pdfWiring/2.pdf here is the link if you didn't see it a little higher.
