Umm... Need Help Bad
Preludedriver
Post by Preludedriver »
So, i was driving and i had my prelude in the sport shift. i shifted it up not at a high rpm and it shuttered in to 4th. Then, stopping at the light in front of me no problem. When i tried taking off it was like it was in neutral and wouldn't go any where. I put it in to 1st on the column(out of the sport shift) and it started going then i put it in 2nd on the column and it wouldn't shift. then in to 3rd and it shifted. (i'm not sure what gear it shifted into). then on to 4th and no shift. i got to where i was going to and and put it in park and now it won't go in to gear.
Also, while driving no speedometer reading and no light on the dash in 2 and 4th when the shifter/stick/selector in the column is in the corresponding gear.
What do you guys got?
Zack
98 Prelude H22
Weapon R cold air intake, cheap eBay full exhuast
Post by rickles8099 »
sounds like you need a new transmission or a transmission rebuild.
Preludedriver
Do you a good guess on about how much it would be todo a 5 speed swap?
Zack
98 Prelude H22
Preludedriver
Shop says it was a fuse. And the ecu put the car in limp mode
Zack
98 Prelude H22
Preludedriver;287893 wrote:Shop says it was a fuse. And the ecu put the car in limp mode
glad to hear it was a cheaper fix. what caused the fuse to blow? and what fuse was it?
Preludedriver
They weren't sure what caused the fuse to blow. I think there's a fuse that controls the tranny but don't hold me to my word.
Zack
98 Prelude H22
