91 crx getting gsr swap
Jhobbs85
doing gsr to crx swap need info
Post by Jhobbs85 »
i have a 95 gsr running gonna be swapping engine tranny and not sure bout axles and brakes into 91 crx
beside the two cars what all will i need
speed
Post by speed »
crazysol
Post by crazysol »
Search that swap before you do it.
Also is the crx multipoint or dual
Need,
Engine, trans, axles, Integra hubs,
Motor mounts, linkage, ecu, some wiring, ect.
Barn-Yard Built..
Jhobbs85
Post by Jhobbs85 »
i have researched but not a specific enough list of what ill need parts wise just i used this or use that i have eng trans ecu will 95 gsr axels work
Post by rickles8099 »
i believe youll need axles from a 90-93 teg and you will need si knuckles for the correct number of splines. and youll need b series shift linkages but im not sure out of what kind of car.
rickles8099;231150 wrote:i believe youll need axles from a 90-93 teg and you will need si knuckles for the correct number of splines. and youll need b series shift linkages but im not sure out of what kind of car.
Si or DX knuckles will work.
zrs6v4
Post by zrs6v4 »
Also you are going from cable to hydro tranny if your planning on using the tranny out of the 95 GSR. Hassport makes a hydro conversion kit or you can always ghetto rig it.
sir_dees1
Post by sir_dees1 »
You will need the 90-93 integra axles and also the intermediate shaft (stamped SK7). If you want to use the brake calipers and 10.25 inch rotors off of the 95 you will also need the knuckles from a 90-93 integra. This is what I have on my crx and the difference is night and day, much better braking than the stock 9.5 inch setup on my stock crx si. With the added weight of the B swap I would recommend this.
The rear trailing arms and disc breaks will bolt up also, make sure you get the 4040 prop. valve from the 90-93 integra also, and if you can get 15/16 master cylinder and matching non abs brake booster,
crxbrad
Post by crxbrad »
You can actually use the axles from your 95. And CRX Si and, I believe DX, knuckles will work.
