timing issue
95_gsrfodo
timing issue
Post by 95_gsrfodo »
ok well the civic i recovered i bought with a bad timing belt...
when tore down i noticed the tensioner bolt was broke as well as the pivot guild that sticks out the motor and u slide the tensioner onto ten bolt it down..
i got the broken bolt out what do i do about the guide pin?
should i just weld a nippel and grind it to make a new on?
leave it as it is?
will it cause a problem?
‎4 Doors = More Whores
95_gsrfodo
timing issue
NOONE has has this problem b4?
timing issue
Post by HardCore97 »
FIRST!!! wait......
Racecore.com
