no fuel
gcef89
no fuel
ok guys i had a thread about this before but i dropped my tank down again to recheck everything and everything checked out fine but my fuel pump still isn't sending fuel to my fuel filter not getting fuel to rail (91 civic si) took my air compressor and blew through all my hoses/lines and air came out fine brand new fuel filter also so i left my fuel pump attached to the harness and put some gas into a bucket to about the top of the fuel pump put my key onto the on position (second click) fuel pump primed but while priming should it send fuel through the feed line while priming?
Boosted_da
no fuel
ok so your fuel pump is getting power right? if so you might have a loose line in your tank btw you can jump you fuel pump from your main relay so you dont have to sit there and turn your ignition on and off
no fuel
Just the way that it mounts up? I don't understand the question. Are you planning on just laying it in there or something?gcef89;271776 wrote:does anyone know if the fuel pump has to sit in the tank any certain way?
