My GSR motor blew and i already have an extra b18b,, so
My question is will the stock gsr wiring harness work for the swap
Plans on using a p75 integra ls ecu.. Will i need to repin the ecu side of the harness, or rewire anything since the new motor has no mad vtec yo..
What other parts will be needed,
Any info will be greatly appreciated.
? help with b18b swap into gsr integra
I doubt you would have to do anything if they are from the same obd family.
datguy
I think this will help
http://www.ff-squad.com/technet/
as long as its the same obd family like said above it will work.
I believe you will have a few loose connections but if its the same obd family it will bridge the sensors with the ecu no prob
