precision injectors
2ksi
Help: precision injectors?
Post by 2ksi »
im looking around for some injectors. i was thinking precision, but do i have to modify they as in solder pigtails in and stuff? or can they plug into the stock injector clips? any info on them would be great!
00 civic si
**fuck playboy there's honda tuning for a reason**
2ksi
precision injectors
Post by 2ksi »
or does anyone suggest different injectors?
00 civic si
2ksi
precision injectors
Post by 2ksi »
bumppppp
00 civic si
precision injectors
Depends on the car. ODB2 hondas will need new clips, but OBD1 and OBD0 cars will be just fine. Also depending on the car/injector choice you might need a resistor box.
2ksi
precision injectors
Post by 2ksi »
its an obd2 car, so what your saying is that because its an obd2 reguardless on what injectors i choose ill have to put pigtails in? are there any injectors that i wont have to put a resistor pack in for? i would really like to not do that. pigtails are fine though.
00 civic si
precision injectors
You will need the resistor box if you use low impedance injectors on a car that came with high impedance injectors like your car.
I am not sure if anyone makes a performance injector with honda OBD2 clips. I know that ere are companies that make adapters so you don't need to solder
2ksi
precision injectors
Post by 2ksi »
alright, thanks for the info. it helps me narrow my searching.
00 civic si
precision injectors
Two companies that make injectors that are high impedance (Saturated, i.e. Don't need resistors).
Plug and Play
http://www.evans-tuning.com/ecommerce/h ... cc-id.html
Pigtails
http://www.deatschwerks.com/civic-b/d/h ... -1992-2000
2ksi
precision injectors
Post by 2ksi »
JustRob;268096 wrote:Two companies that make injectors that are high impedance (Saturated, i.e. Don't need resistors).
Plug and Play
Pigtails
thanks! i was told to go with deatschwerks by my buddy. this helps alot.
00 civic si
