why am i burning oil?
ilovemyd16
Post by ilovemyd16 »
why does my y7 burn so much oil. i burnt two quarts of oil from the last oil change what the hell do i do
deetz
Post by deetz »
could be many things, from bad valve seals, to h/g, to rings, need more info on car, like mods andfd mileage
~chris~
-scca setup 99 grand am gt
-85 cj7
ilovemyd16
well its a 97 civic dx with nothing but a aem short ram and a ebay axle back. 151k miles on it
deetz
Post by deetz »
check plugs, then do a leakdown or have a shop to a proper leakdown/compression test
~chris~
-85 cj7
ilovemyd16
thanks i just bought ngk plugs i should put them in i guess
Welcome to owning a high mileage Honda.
Burning one quart of oil every 1,000 miles is still considered normal according to Honda. Make sure to check your engine oil regularly and that there are no external engine oil leaks.
ilovemyd16
will do lol should i rebuild this thing before i turbo?:stickman:
Thatoneguy
Post by Thatoneguy »
ilovemyd16;265963 wrote:will do lol should i rebuild this thing before i turbo?:stickman:
Yes!
Or better yet swap in a b18b and build on that, then turbo later on.
Well, it's not going to help your oil consumption.
If it were my car, I would do a compression test first. If compression is still within range and I only wanted to make a maximum of 180 WHP, I would turbocharge it so long as I used a proper setup. This means quality parts with an adequate crankcase ventilation setup, fuel system, EMS and tune.
Another thing to keep in mind is D16Yx engines tend to have bearing issues near the 150k mile mark. It wouldn't be a bad idea to keep a spare around just in case. They're cheap enough now days.
ilovemyd16
wanna do a turbo y7 lol bit thanks for all the help
