Rear disc conversion question
ejtuner88
Post by ejtuner88 »
I just converted the rear brakes on my '93 civic to disc and i know i need a new proportioning valve and the guy i bought the kit from gave me one, but im not sure if its the right one. it has 4 holes for lines whereas the original has 6. if anyone can verify if i have what i need or has the one i need let me know. i wanna get her back on the road asap.
v-tecivic
Post by v-tecivic »
which one does it look like?
97 civic ex turbo
13.1@112
ejtuner88
Post by ejtuner88 »
the original looks like the second one. the one i got with my kit doesn't look like either one of those. it has 2 fittings on one end, two on the other.
Post by andyjt »
ejtuner88;203631 wrote:the original looks like the second one. the one i got with my kit doesn't look like either one of those. it has 2 fittings on one end, two on the other.
Thats off of a ABS car then. Its not a prop valve either. Youll need one off of a non-abs car.
ejtuner88
Post by ejtuner88 »
i knew i was gonna need one of a non-ABS car, i just wasn't sure if the one he gave me was for an ABS car or not. i guess ill just have to buck up and order one from the dealer. unless someone has a valve off a non-ABS SI. i know that would work.
Post by andyjt »
ejtuner88;203637 wrote:i knew i was gonna need one of a non-ABS car, i just wasn't sure if the one he gave me was for an ABS car or not. i guess ill just have to buck up and order one from the dealer. unless someone has a valve off a non-ABS SI. i know that would work.
Some Automatic EX's 96-00 had rear disks as well.
crxspeedsir
Post by crxspeedsir »
I used the 91 integra prop for my crx works great and there easy to find
Obama=Osama
Impeach Obama
Save America
:assault:
spoon_fed_civic
Post by spoon_fed_civic »
andyjt;203639 wrote:Some Automatic EX's 96-00 had rear disks as well.
im pretty sure all 92-up EX 4 doors have rear disk.i know every one i have own has had them.
aftermarket prop valves arent expensive and are also adjustable if you cant find the right one.
sir_dees1
Post by sir_dees1 »
the one you need will be stamped 40/40
