92 Accord with oil in the spark plug "tubes"
JohnnyChon
Post by JohnnyChon »
Just bought a '92 accord with the 2.2L. Was checking through things to do a tune up and found oil under the spark plug boots basically filling the tubes down to the plugs. The previous owner said it leaked oil so I figured this was it. I replaced the valve cover gasket and still getting oil in there.
Any ideas?
Did you replace the gaskets on the valve cover that seal the tubes from the rest of the head?
JohnnyChon
Yes. They all came with the set. There were 4 o-rings that i didn't know where they went...There weren't anything like that on the old gasket.
Post by andyjt »
JohnnyChon;235458 wrote:Yes. They all came with the set. There were 4 o-rings that i didn't know where they went...There weren't anything like that on the old gasket.
Those additional 4 o-rings go between the head and the camshaft caps/ spark plug seals .
budget_crx
Post by budget_crx »
andyjt;235460 wrote:Those additional 4 o-rings go between the head and the camshaft caps/ spark plug seals .
which is where the leak is coming from, so go fix it!
