need a mechanic for a cam install recommendations?
red dragon
Post by red dragon »
looking to get my cam, crank underdrive pully, timing belt and valve seals installed thanks
1994 CIVIC SI HATCH STAGE2 VENOM INTAKE,62MM TB,CAI,VTEC COTROLLER, HEADER,2.25 EXAUST,NGK PLUGS,8MM WIRES,AC AND PS DELETE TO BE INSTALLED CROWER STAGE 2 CAM CRANK UNDERDRIVE PULLY
Post by Capt'n Obvious »
ditch the crank pulley i took one off and used plyers to hold it while we took off the bolt and it bent
no l in crower
