I knew someone would knowandyjt;218799 wrote:I believe they are Thermo valves. Basically temperature heats up on valve an opens the other end of the vaccum port. They are pretty common in junkyards among almost all carbed hondas. Actually lemme check i might have on in my basement you could have.
-Andrew
that would be pimp andy. let me knwo man. Thanks!andyjt;218799 wrote:I believe they are Thermo valves. Basically temperature heats up on valve an opens the other end of the vaccum port. They are pretty common in junkyards among almost all carbed hondas. Actually lemme check i might have on in my basement you could have.
-Andrew
