accord H22 swap question
tommygun89hb
Post by tommygun89hb »
Ok so i am getting ready to swap an h22 in my accord.
I have done reserch on this topic but cannot find a deffinate answer on it.
I have read that you can use the prelude sh manifold and it will bolt up to the down pipe on the accord without getting anything manufactured???
Does anyone know if this is true?????
crx08
Post by crx08 »
look at where the sh manifold will bolt up to the accord section and that should tell you if it will work or not. try to find a picture of the manifold so its easier
stl-imports.com/forums
tommygun89hb
I think i have figured it out. thanks buddy
crx08
Post by crx08 »
what did you do? I'm curious
tommygun89hb
well the Sh manifold will work but you need the complete system
manifold,downpipe, it comes with the adapter to and you can use the rest of your accord exaust.
The h22 a manifold you have to have
cat,down pipe, manifold and you have to have an exaust shop cut and weld your exsisting exaust because that set up will only leave about 2 inches for the cat to bolt up.
This is for a 94-97 accord
