SOHC to DOHC
stephen1124
SOHC to DOHC
Post by stephen1124 »
Okay I'm sure you've all been asked this a million times but, I'm askin again. I have a d16y5 SOCH VTECH. Is it possible to convert this into a DOCH without doing an entire motor swap given they are both 1.6L 16 valve engines? If so how do I go about doing so?
v-tecivic
SOHC to DOHC
Post by v-tecivic »
first, you'll need to remove your sohc motor/trans. next you will need to install the dohc motor/trans. thats the only way...
97 civic ex turbo
13.1@112
Rich
SOHC to DOHC
Post by Rich »
Well the first step is to convert that SOCH to an SOHC then we can move onto working on the DOCH swap. But the DOCH swap to DOHC swap is extremely difficult.
2008 Chevy Slobalt
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
Hope this helps
Yes I own 2 slow red chick cars & 1 real car!
sharpie
SOHC to DOHC
Post by sharpie »
i might be wrong but, i think you can use the dohc zc swap but thats pretty much useless. you could make more power and be more reliable staying with the sohc. unless you want to do a whole motor and trans swap to dohc like a b, k, or h
SOHC to DOHC
Post by andyjt »
stephen1124;204161 wrote:Okay I'm sure you've all been asked this a million times but, I'm askin again. I have a d16y5 SOCH VTECH. Is it possible to convert this into a DOCH without doing an entire motor swap given they are both 1.6L 16 valve engines? If so how do I go about doing so?
Keep the SOHC. I recently did a DOHC to SOHC swap into my Integra Type R. I must say it was a VERY nice improvement in the powerband.
v-tecivic
SOHC to DOHC
Post by v-tecivic »
andyjt;204172 wrote:Keep the SOHC. I recently did a DOHC to SOHC swap into my Integra Type R. I must say it was a VERY nice improvement in the powerband.
technically wouldn't that be a dual sohc?
97 civic ex turbo
13.1@112
SweetEBPSi
SOHC to DOHC
Post by SweetEBPSi »
lol. Don't forget to mention the 2 extra cylinders you added as well.
SOHC to DOHC
Post by andyjt »
v-tecivic;204176 wrote:technically wouldn't that be a dual sohc?
No. 1 cylinder per head = sohc.
SweetEBPSi;204177 wrote:lol. Don't forget to mention the 2 extra cylinders you added as well.
so....
stephen1124
SOHC to DOHC
Thanks guys that was really swell advise. lol So then can you tell me why I cant accelerate while driving up inclines? I can usually maintain speed but can't gain.
sharpie
SOHC to DOHC
Post by sharpie »
stephen1124;204188 wrote:Thanks guys that was really swell advise. lol So then can you tell me why I cant accelerate while driving up inclines? I can usually maintain speed but can't gain.
cause you have a n/a not built d16 thats normal lol
