My ghetto engine build/plans
Well some of you know I am going back to Honda and I have started building my ghetto engine. Anything that does not list a brand I am open to suggestions.
Plans 500HP on a B18A/B
Parts to buy/acquire:
Filled and posted B18A/B block
Reground Cams(unknown specs yet)
Valve springs/retainers
ARP Main and Head Studs
low Comp pistons
DIY Valve cover breather
Cam gears
Venom Intake Manifold(or one of similar design)
Parts in hand:
T3 Turbo Manifold
70 Trim T3/T4
Eagle ESP Rods
B20 Head(will be ported and polished with larger valves)(Thanks Dale!)
I am open to suggestions/changes.
twkdcd595
Post by twkdcd595 »
Maybe look at Wiseco for a decent quality but reasonably priced piston since your on a budget.
I am not sure you will be needing ARP main studs unless you found some cheap or something. They are overkill from what I seen, alot of people have run stock main bolts without issue.
