Test Pipe
01luda
Test Pipe
Post by 01luda »
If anyone is running a test pipe and needs to get rid of the cel code po42o this forum wright up will help. Ive done this to my lude and its been a year and no cel light. Passed emissions and all is good. http://forums.evowned.com/showthread.php?t=3116
Test Pipe
Post by RyanA »
Yes, it's definitely a cheap fix that works on probably 80% of the cars out there.
Test Pipe
worked on my old honda, and some day soon it might work on my eclipse.
Acme Importz
Test Pipe
Post by Acme Importz »
That works great , but most states require a cat , you can run the pipe through a gutted one for inspection purposes .
kodycobra
Test Pipe
Post by kodycobra »
01luda;198120 wrote:If anyone is running a test pipe and needs to get rid of the cel code po42o this forum wright up will help. Ive done this to my lude and its been a year and no cel light. Passed emissions and all is good. http://forums.evowned.com/showthread.php?t=3116
This method does work well. I've done it since back in my Mustang days with 100% success.
Test Pipe
and if you guys o2 heater code then its also real easy to fix. all you need is a 10 watt 50ohm resistor from radio shack and cut the two black wires coming off the o2. dont do anything with the two wires left on the o2 sensor but on the harness side just connect the 2 black wires to the ends of the resistor.. basically running the resistor inline with the 2 black harness side wires. dont need o2 heater anyways and doesnt affect anything.
