f22 help plz
thelastloser
f22 help plz
i got a 97 accord and my engine started knocking so i bought another car wit f22 and i noticed that the bolt pattern for the transmission was different but from what i have read online it should be fine is this true.
tommygun89hb
f22 help plz
hmmmmmmmmmmmmmm thats weird because f seiries and h series trannys are inerchange able what does the transmission code say it is?
You can look at the barcode in white and read the tranny code
kra95civic
f22 help plz
unless it had a weird tranny swap like f2b or f2d but y the fuck would they sell that.
twkdcd595
f22 help plz
x2.tommygun89hb;197702 wrote:hmmmmmmmmmmmmmm thats weird because f seiries and h series trannys are inerchange able what does the transmission code say it is?
whats the transmission codes... as most all of the transmissions are interchangeable and bolt right up among the f/ h series.
thelastloser
f22 help plz
the bad engine is a f22 out of my accord the other engine is a f22 out of a cl.
v8this
f22 help plz
get the code off the transmission because all f series and h series transmission should interchange...
thelastloser
f22 help plz
the transmission off the engine im using is s2a4-1006222
the one im using is boya800227a or vpoh60 i could be off cause i the second one was covered in old oil from the engine.
