Overheating Problems
J.M.P
Post by J.M.P »
HI, Im still having overheating problems. I replaced the hose that was leaking the coolant, so there are no leaks anymore, but it still overheats.
Any help here will be appreciated.
Here are the scenarios I have run through.
I started the car, runs fine, the upper radiator hose is really hot, even when slightly cold, the lower radiator hose is cold all the time.
The AC fan kicks on no problem, but the other fan never kicks on.
I read that flushing the whole system will help, the radiator, all hoses etc? good idea i suppose?
I did notice that the upper radiator hose is really bulgy, like its backed up, I will post a pic for you to look at.
Thermostat
J.M.P
Post by J.M.P »
Thanks, Im gonna look at it, replace. Hopefully that is it.
btlfed7;193076 wrote:Thermostat
cyclohonda;193084 wrote:Thanks, Im gonna look at it, replace. Hopefully that is it.
Pull it out, throw it in a pot of water on the stove. put a thermometer on it and see at what temp it opens.
gsrauto98
Post by gsrauto98 »
And also jump the fan to the battery to see if it comes on then, if not then your fan motor is bad, if it does kick on then replace the fan switch
J.M.P
Post by J.M.P »
ok yea i will check that to. thanks.
gsrauto98;193141 wrote:And also jump the fan to the battery to see if it comes on then, if not then your fan motor is bad, if it does kick on then replace the fan switch
J.M.P
Post by J.M.P »
well today I flushed all the coolant, changed the radiator hoses both upper and lower, and put another new bypass hose, that fit better, also put a new thermostat on, here is what the old one looked like compared to the new one obviously on the left is the new one.
Hoping that this will fix my problem, if not then on to other things.
J.M.P
Post by J.M.P »
well everything is fixed now, and running good, no overheating, no leaks, and coolant temp running low.
Thanks for the help!!
4Door
Post by 4Door »
should have went with an OEM thermostate IMHO
H.E.A.R.T
J.M.P
Post by J.M.P »
What is the real difference? will this one not hold up as good, or?
4Door;193342 wrote:should have went with an OEM thermostate IMHO
