Block ?'s
Leprechaun86
Block ?'s
Post by Leprechaun86 »
Hey guys i'm puttin a D15B7 into a 90 wagovan. It had the D15B2 which had two plugs on the back of the block. One im sure is the oil pressure sensor. What the other is im not sure. Need to know though because the B7 block has only one Sensor any help would be great.
forcefed
Block ?'s
Post by forcefed »
Pics would be great
boxbodyblazer
Block ?'s
Post by boxbodyblazer »
Temp sensor?
Block ?'s
Coolant fan switch.
tj87
Block ?'s
Post by tj87 »
Yep it is the Coolant fan switch.
They switched the location to the thermostat housing (rear passenger's side of the block).
You are going to have to extend the wires and solder on a plug from a D15B7.
Just did this last week it is super easy to do.
Leprechaun86
Block ?'s
Thank you for your help good sirs
