D-Series ?
Leprechaun86
D-Series ?
Post by Leprechaun86 »
I found a d15b8 for $100 on the ole craigslist. And what I wanted to no is well the dpfi manifold bolt to that head??? The guy says that the motor is out of a 93 civic. That is the only info I know.
Thanks, Rich.
D-Series ?
It will bolt up but I believe the coolant passages are in different places and the intake ports won't line up at all, considering you're putting a 16 valve intake manifold on an 8 valve motor. Just do an MPFI conversion and use the stock D15B8 manifold.
