95 Integra, weird wiring issues, ?'s.
Digital Sol
Post by Digital Sol »
Working on a buddy from work's 95 integra. The front end was smashed up and the previous owner wired everything up like a 6 year old'.
With that said everything "was" working normal for a few days after he bought it'. Now when you turn on the headlights the left blinker stays solid and the e-brake light comes on. All fuses are good', im working on figuring out how the wiring "should" be wired via diagrams and trying to track down turn signal plugs w/bulb and blinker plates for the oem bumper.
Mainly wanting to know if there is a particular re-lay that could cause this issue, if so which one and what is the proper/best way to test a relay with a volt meter.' Sense its not my car i will not be purchasing relays left and right and playing the swap game.
