water temp sensor
water temp sensor
ok so i changed out the sensor for a brand new one and checked the wiring and its good and it still keeps throwing the CEL for the water temp sensor. anyone got any ideas? this is driving me crazy
Racecore.com
Racecore.com
water temp sensor
the water temperature sensor. looks like this
heres another pic of what im talking about just so you can see it on the head
Racecore.com
Racecore.com
water temp sensor
Did you remove the backup fuse to clear any codes?
I dunno.....worse case I would bypass the car harness and run the signal wire straight to the ecu.
water temp sensor
what are you calling the back up fuse? the one in the underhood fuse box for the ecu?
Racecore.com
Racecore.com
water temp sensor
There should be a ~7.5 amp fuse in the underhood fuse box. I believe it stores codes as well as keep constant power on the radio.
It is right next to the ecu fuse in both 5th and 6th generation civics. If you do clear that code and it still comes up...something is still triggering it obviously.
water temp sensor
ive pulled that fuse to reset it yes. but that code keeps coming back on. i guess i may have to try running my own wires and see what happens
Racecore.com
Racecore.com
