question on dc header for lude...
01luder
guy gave me dc sport header for free, the downpipe flex pipes wire mesh cover is rotted and torn and cannot be used if its is not cut welded and modifications are made which was qouted at 200 so will the top part simply bolt on to my factory downpipe? if so will a power/air flow gain still be made?
99PreludeSh
You wont gain any kind of power with that header, it has the stock OEM specs its just "prettier" also it will bolt up yes.
01luder
ok will thier be a sound change at least and there has to be some kind of gain i mean with the mandrel bent tubing and larger circumference?
99PreludeSh
you will see MAYBE a 1hp gain thats about it, they literally have the OEM specs.
