obd 0 to obd 1 help
civicex442
obd 0 to obd 1 help
i need someone to tell me what i need. i have a 89 crx with harness. i have a d16z6 with harness and p28. i know i need a cable to hydro converter. what else? and what harness do i use?
98 EJ6
03 WRX
tommygun89hb
obd 0 to obd 1 help
well if the crx is a Duel point fuel injection you need to convert it over to multi point (look on the web plenty of write ups or ask someone on here how to do it) you need a ob0-obd1 jumper harness you can find them all over the web. you need the ef left side motor mount and if i for get anthing else im sure some one will let me know.
obd 0 to obd 1 help
all that and youll need to use the harness that came with the car.
civicex442
obd 0 to obd 1 help
its mpfi. so i use the obd 0 harness? will i need to change over any sensors?
obd 0 to obd 1 help
youll need an obd1 vtec distributor, obd0 to obd1 conversion harness, and a heated o2 sensor.civicex442;139614 wrote:its mpfi. so i use the obd 0 harness? will i need to change over any sensors?
obd 0 to obd 1 help
Troof, you can get the obd-0 to obd-1 ecu harness at rywire along with that harness it has the 4 wire o2 output you just wire in.rickles8099;139619 wrote:youll need an obd1 vtec distributor, obd0 to obd1 conversion harness, and a heated o2 sensor.
civicex442
obd 0 to obd 1 help
thanks guys. thats all i needed to know
