My F*%#cking idle problem
slammeds2k
Post by slammeds2k »
Alright heres my problem and yes my other thread was related to it. This is more in detail and more simplified thank you. I start my car and it idles fine it will idle all day if i let it. I then raise the rpms past like 5 or 6 and after it lowers it either dies or stumbles from like 2 to 4 hundred rpm. If it dies it will start right back up and idle great again. It will do this everytime right on cue. I have tried cleaning my IAC and doing a MAP whack. I took the MAP off and cleaned every part on the throttle body. I have checked every vacume line on the dang car. I have pulled them off to see if the idle cahnges. I am goin to perfom a vacume test tomorow. Help please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I beg you!!!!
