If i change cams do I change sping retainers?
slammeds2k
Post by slammeds2k »
I wanted to swap to a skunk stage 2 cuz i already have my head off but i was told at trusty ADRENALINE:angry7: that those two go hand in hand so wasnt sure?
Post by Phate »
Skunk2 wrote:· Camshafts will place greater stresses on valvetrain components and cause higher rates of wear
· Valve train upgrade is required. We strongly recommend the use of Skunk2 Pro Series valve springs (P/N 311-05-5410) and titanium retainers (P/N 308-05-0420).
I guess its up to you though.
Depending on the cam you will need to change the springs and retainers. The cam you selected does require you to do the srpings and retainres. Also you might wat to see about doing the valve guides while you have the head off.
